sheetcam TNG vers mach3
  • Auteur de la discussion Auteur de la discussion mickael72
mickael72
bonjour à tous,
j'ai un souci, entre sheetcam et Machs 3 .
sur sheetcam, j'arrive à sortir un programme g code, mais se programme me paraît vraiment très court .
mon post processeur sur sheetcam, est bien sur mach 3 plasma .
quelques images pour comprendre ;
et voici le malheureux g code qu"il me génère : 7 lignes :mad::mad::mad::mad::mad:
function OnAbout(event)
ctrl = event:GetTextCtrl()
ctrl:AppendText("Mach3 plasma post processor\n")
ctrl:AppendText("\n")
ctrl:AppendText("Generic plasma post for machines without THC\n")
ctrl:AppendText("Modal G-codes and coordinates\n")
ctrl:AppendText("Comments enclosed with ( and )\n")
ctrl:AppendText("M03/M05 turn the torch on/off\n")
ctrl:AppendText("Incremental IJ\n")
end
-- revision 3/2/07
-- Removed final safety move. This is now done in SheetCam
-- revision 7/10/05
-- Added new arc handling
-- revision 11/7/05
-- Moved torch to cut height when preheating
-- Added dummy spindle speed to prevent Mach2 throwing a zero spindle speed error
-- revision 9/10/04
-- Added preheat
-- revision 28/6/04
-- Replaced startx,y,z with currentx,y,z
-- created 28/5/04
-- Based on Mach2 metric.post
function OnInit()
post.SetCommentChars ("()", "[]") --make sure ( and ) characters do not appear in system text
post.Text (" (Filename: ", fileName, ")\n")
post.Text (" (Post processor: ", postName, ")\n")
post.Text (" (Date: ", date, ")\n")
if(scale == metric) then
post.Text (" G21 (Units: Metric)\n") --metric mode
else
post.Text (" G20 (Units: Inches)\n") --inch mode
end
post.Text (" G53 G90 G91.1 G40\n F1\n S500\n")
bigArcs = 1 --stitch arc segments together
minArcSize = 0.05 --arcs smaller than this are converted to moves
end
function OnNewLine()
post.Text ("N")
post.Number (lineNumber, "0000")
lineNumber = lineNumber + 10
end
function OnFinish()
post.Text (" M05 M30\n")
end
function OnRapid()
post.ModalText (" G00")
post.ModalNumber (" X", endX * scale, "0.0000")
post.ModalNumber (" Y", endY * scale, "0.0000")
post.ModalNumber (" Z", endZ * scale, "0.0000")
post.Eol()
end
function OnMove()
post.ModalText (" G01")
post.ModalNumber (" F", feedRate * scale, "0.0###")
post.Eol()
end
function OnArc()
if(arcAngle <0) then
post.ModalText (" G03")
else
post.ModalText (" G02")
end
post.NonModalNumber (" X", endX * scale, "0.0000")
post.NonModalNumber (" Y", endY * scale, "0.0000")
post.Text (" I")
post.Number ((arcCentreX - currentX) * scale, "0.0000")
post.Text (" J")
post.Number ((arcCentreY - currentY) * scale, "0.0000")
post.Eol()
end
function OnPenDown()
if (preheat > 0.001) then
post.ModalNumber (" Z", cutHeight * scale, "0.0000")
post.Text ("\n G04 P")
post.Number (preheat,"0.###")
post.Eol()
end
post.ModalNumber (" Z", pierceHeight * scale, "0.0000")
post.Text ("\n M03\n")
if (pierceDelay > 0.001) then
post.Text (" G04 P")
post.Number (pierceDelay,"0.###")
post.Eol()
end
end
function OnPenUp()
post.Text (" M05\n")
if (endDelay > 0) then
post.Number (endDelay,"0.###")
post.Eol()
end
end
function OnNewOperation()
post.Text (" (Operation: ", operationName, ")\n")
end
function OnComment()
post.Text(" (",commentText,")\n")
end
function OnToolChange()
post.Text (" M06 T")
post.Number (tool, "0")
post.ModalNumber(" F",feedRate * scale,"0.0###")
post.Text (" (", toolName, ")\n")
if (plungeRate <= 0) then
post.Warning("WARNING: Plunge rate is zero")
end
if (feedRate <= 0) then
post.Warning("WARNING: Feed rate is zero")
end
end
function OnNewPart()
post.Text(" (Part: ",partName,")\n");
end
function OnDrill()
OnRapid()
OnPenDown()
endZ = drillZ
OnMove()
OnPenUp()
endZ = safeZ
OnRapid()
end
Pour le plasma je ne sais pas parce que j' utilise Sheetcam pour du fraisage ,mais j'ai l'impression que tu as lancé le Postprocessor sans éditer d'opération (le cadre en dessous des outils) ....??
Dans l'onglet Option et sous menu Machine ,as tu bien coché l'option découpe au jet ?
oui a mon avis aussi tu a pas editer l'operartion car tu devrais voir les trajectoires et l'ordre ce coupe
merci a vous , voici un essais avec avec la sélection découpe jet ,
mais pas mieux 9 lignes de g code .
une image du résultat.
voila une fois que tu a fais les trajectoires de coupes tu doit executer le poste prost processeur, l'a tu fait? car il va generer le gcode. il te demande dans quel dossier tu veut l'enregistrer au format TAP que tu pourra ouvrir dans mach 3 plus tard
sinon si tu lance la simulation dans sheetcam ca donne quoi?
tu as généré une operation avec le calque 0 ,hors celui qui est concerné est "2 platines....",il est possible qu'il n'y ait aucun gcodes de sortis a cause de ça ... peus tu verifier ?
tu as bien une licence valide ,vérifie aussi si elle est bien reconnue (menu "Aide, A propos )
Tiens nous au jus
amicalement
salut dardar88 j'ai tout essayer sa ne veux pas marcher ,
licence bien valide , j'ai suivi t on conseil sélection du calque de la pièce et rien ni faite une vrais misère , première fois que un logiciel me résiste :mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad:
je suis maudit !!!!!!!!!!!!!!!!!!!!!
bonsang d'bonsouèr ,moi j'y arrive ,je suis en version Win (7)
j'ai juste edité en contour interieurs avec 1 seul calque mais j'aurais du en faire deux,
1 pour le contour de la plaque en exterieur et 1 pour les trous en interieur pour coller a ton dessin.
Je n'ai pas renseigné la longueur de l'arc ,c'est juste pour le test...
SheetcamTNG standard ,pas la version Dev mais ça ne devrait pas changer grand chose.
Il ne faut pas oublier non plus ,dans le choix des Machines (option) de décocher
"outil tournants" si on choisit la découpe par jet ,je me suis fait avoir :)
Capture :
Après Postpro:
Sham
Sham
El Zorro
El Zorro
El Zorro
lecoyote
Greg de Nîmes
zingilingiling
zingilingiling
MickB26
papy62
Gabrielp
Tristan l'apprenti
Dardar88
xc1387
enp.metal
enp.metal
