joystick
  • Auteur de la discussion Auteur de la discussion Anonymous
Guest
Salut, j'aurais voulu mettre un joystick pour commander ma fraiseuse, en effet ,le pad sans fil que j'utilise est toujours plein de copeaux.................par contre oû est ce que je paramètre le joy dans mach ?
ch 3.2
The another option for jogging is a joystick connected
to the PC games port or USB. Mach3 will
work with any Windows-compatible “analog joystick”
(so you could even control your X axis by a
Ferrari steering wheel!). The appropriate Windows
driver will be needed for the joystick device. The
'stick is enabled by the Joystick button and, for safety, must be in the central position when it is
enabled.
ramses76
Marc le Gaulois
Papygraines
Papygraines
Papygraines
Lionel Risler
mad max 43
mad max 43
Vik'TheBike
kerdour29
Dope 54
serrepattes
Mathand
fredobob
ingenieu59
ingenieu59
