Problem omron CIMR V7AZBOP7
Discussion dans 'Electricité, variateurs, convertisseurs et moteurs' créé par IOAN, 19 Août 2014.
  1. IOAN
    IOAN Nouveau
    Inscrit:
    5 Février 2013
    Localité:
    ROMANIA -KN35 AJ
    I bought VARISPEED V7 OmronV7 V7AZBOP7 1.1 KW
    the seller was setting parameters for him use
    I have driving 3x220V/50Hz and current consummation it is 2,9 A
    my Omron v 7 no good function
    so, when command ,, RUN,, the driving start for 0,5 " secundes and stop
    the display information cod faulty OL3
    for resolve problem must ajuste u 098 and u 080 here not understand .
    193 and 93 manual service pages.
    Best regardes
    and wait yours replay
    IOAN
  2. Chani
    Chani Compagnon
    1 167
    Inscrit:
    6 Novembre 2009
    Localité:
    54, Auboué
    sorry for the delay of my response. I don't go every day on this forum.
    Well, if i had a good understanding of your problem, it could be several case :
    - the current leak to the earth is too important. You can minimize it with a shield on your cable or with a decrease of the fundamental frequency. This could be done with the n080 parameter. You should set it at "1", to have a base frenquency at 2.5kHz. The motor noise could be bigger, but the jam is lower.
    - the load on the motor is to large. You can adjust the current tolerance with the parameter n098. The factory setting is quiet good, you can set at 160 %.
    Could you tell me if the default OL3 blink or is constant ?
    Have a nice day. Best regards.
  3. IOAN
    IOAN Nouveau
    Inscrit:
    5 Février 2013
    Localité:
    ROMANIA -KN35 AJ
    hello sir , I receivers your signal and tomorrow I try adjust parameters 080 and 098 . See in the my listing with all parameters :x I mistake because n080 =4 and 098
    it is 120 % The ,,OL3,, it is constant.
    ok tomorrow you have result, I hope will be good.
    Best regardes
    IOAN
    n 001 4 n 031 57,00 n 061 0 n 091 0,0 n 121 0,00 n 151 0
    n 002 0 n 032 6 n 062 0,10 n 092 0 n 122 0,00 n 152 0
    n 003 0 n 033 100 n 063 0 n 093 170 n 123 0,00 n 153 0
    n 004 0 n 034 0 n 064 0 n 094 160 n 124 0,00 n 154 2
    n 005 0 n 035 0 n 065 0 n 095 0,00 n 125 0,00 n 155 0
    n 006 0 n 036 2,9 n 066 0 n 096 4 n 126 0,00 n 156 10
    n 007 1 n 037 1 n 067 1,0 n 097 00 n 127 0,00 n 157 0
    n 008 1 n 038 8 n 068 1,0 n 098 120 n 128 0 n 158 225,0
    n 009 0 n 039 0 n 069 0 n 099 0,1 n 129 1,00 n 159 12
    n 010 0 n 040 0 n 070 0,10 n 100 0 n 130 1,0 n 160 12
    n 011 100 n 041 10 n 071 100 n 101 2,0 n 131 1 n 161 3,3
    n 012 230 n 042 10 n 072 0 n 102 150 n 132 0,00 n 162 2,5
    n 013 50 n 043 10 n 073 0,10 n 103 1,0 n 133 0 n 163 1,0
    n 014 1,3 n 044 10 n 074 100 n 104 0,3 n 134 100 n 164 0
    n 015 12 n 045 0,00 n 075 0 n 105 6,5 n 135 0,0 n 165
    n 016 1,3 n 046 0 n 076 0,10 n 106 5,0 n 136 0 n 166 0
    n 017 12 n 047 0 n 077 0 n 107 2,575 n 137 0 n 167 0
    n 018 0 n 048 0,0 n 078 0 n 108 19,07 n 138 1,0 n 168 0
    n 019 1,5 n 049 1 n 079 10 n 109 150 n 139 0 n 169 0,0
    n 020 1,0 n 050 1 n 080 4 n 110 50 n 140 50 n 170 0
    n 021 1,5 n 051 2 n 081 2 n 111 1 n 141 0 n 171 0,0
    n 022 1 n 052 11 n 082 0 n 112 1,0 n 142 0,2 n 172 0,0
    n 023 0 n 053 5 n 083 0,00 n 113 0 n 143 1 n 173 83
    n 024 47,00 n 054 6 n 084 0,00 n 114 2 n 144 1,00 n 174 25
    n 025 36,00 n 055 7 n 085 0,00 n 115 0 n 145 0 n 175 0
    n 026 43,00 n 056 8 n 086 0,00 n 116 0 n 146 0 n 176
    n 027 50 n 057 6 n 087 ---- n 117 0 n 147 58 n 177 0
    n 028 33 n 058 0 n 088 ---- n 118 10 n 148 2500 n 178
    n 029 40 n 059 2 n 089 50 n 119 0,1 n 149 0 n 179 ??
    n 030 50 n 060 100 n 090 0,5 n 120 0,00 n 150 n 180 5740
  4. IOAN
    IOAN Nouveau
    Inscrit:
    5 Février 2013
    Localité:
    ROMANIA -KN35 AJ
    tnx for all, I resolve problem .
    I mistake , the elementary notion physical about construction asincron drivers
    so, when make delta connection 3X220V for use with inverted , I forgot coonectios the coil A,B,C . The beginning of the end coil driver must connect beginning coil A with end coil B ....etc.
    Now my OMRON a good functions and the setting parameters I can make steep by steep conform manual service .
    Best regardes IOAN
Chargement...
Partager cette page
