abuil
Je viens de trouver une autre doc du variateur. En effet il est question de 2 switchs mais ce n'est pas très clair pour moi
SWITCH SETTINGS
Use the switches on back of the Display/Adjustment options as described in the following sections. Refer to Tables 1 and 2 for a summary of switch settings.
For location of the switches on option VW3-A16101, see Figure 1 on page 1. For location of switches on option VW3-A16102, see Figure 2 on page 2.
Note:
In Table 1 and Table 2, Drive Ready indicates that power is applied to the drive controller, but no Run command is present
- Switch 1 (VW3-A16102 Only)
Switch 1, used on option VW3-A16102 only, selects local control. When Switch 1 is set to On, the drive controller is in Local mode. With the presence of a direction com-
mand (FW/RV) and reference frequency set with the parameter, the drive controller may be started, stopped and reset from the Display/Adjustment option,
depending on settings of the RES, STS and STE parameters (see page 13).
When Switch 1 is set to Off, the drive controller is run only with the presence of a direction command (FW/RV) and reference signal at AIV or AIC.
- Switch 2 (VW3-A16101 and VW3-A16102)
Switch 2 is used on both options to determine the mode of the Display/Adjustment option. When Switch 2 is set to On, the option is in Set-up mode.
Set-up mode permits modification of parameters when the drive controller is ready or the motor is running. See Table 1 for further explanation.
When Switch 2 is set to Off, the option is in Adjustment Lockout mode. No modification of parameters is possible in this mode. See Table 2 for further explanation.
SWITCH SETTINGS
Note:
